Dox
1.8T AUM (drive by wire) engine, ancils, loom, revo'd ecu forge DV etc
For sale 1.8T AUM (drive by wire) engine, ancils, loom, revo'd ecu forge DV, G60 flywheel, starter, front mount.
This engine has done 160K in a Skoda Octavia L & K estate, the previous owner commuted from Cannock to Derby daily, serviced every 10K on the dot, no oil leaks (the PAS pump did mist a little around its mounting), no coolant leaks or losses. I drove the car for 14K miles before I broke it, no sweat. Its due a cambelt and water pump.
Offers around £400
Options include;
The original EVS gearbox - known all good
A MK3 GTI 16V gearbox - bought off another forum
A G60 engine loom (so that you could sort the loom plug and play for a faster change over reducing downtime)
If no interest in the next 7 days I'll begin to part out the above.
Thanks
Now on other forums, its the full set up for the price of a charger rebuild. I was quoted £300 to remove the immobiliser and wire the 1.8T loom to the g6o fuse box loom
ECU with REVO remap £100
Forge DV £50
Engine loom £60
Throttle body £40
Inlet manifold £40
Coils £10 each, 4 for £30
Alternator £30
MAF £30
1.8T clocks £50
1.8T EVS gearbox £50 (no shift tower)
G60 clocks £50
Golf (ABF) CDA 16V gearbox £50 (no shift tower)
ABF starter £20
Front mount bracket £15
G60 flywheel £40
Belt tensioner £15
All plus P&P
Edited by Dox
No idea, came with the car, dirty in the pics and needs a polish
any pics of the belt? tensioner? is that £15 posted?
Dan
I'll get a pic tomorrow, its going to cost me £7 to post via myhermes
