sexybourbon 0 Posted October 3, 2013 Can someone recommend me some good bulbs for the headlights Coming upto winter so need to sort out some decent lights Quote Share this post Link to post Share on other sites
GlosterOx 0 Posted October 3, 2013 These aren't bad for the price, work well too with one of Kur2y's uprated looms: http://www.amazon.co.uk/Osram-Night-Breaker-Extreme-Sidelights/dp/B004J3DJI4/ref=sr_1_6?ie=UTF8&qid=1380830779&sr=8-6&keywords=osram+night+breaker+plus Ian. Quote Share this post Link to post Share on other sites
sexybourbon 0 Posted October 3, 2013 Cheers mate never had to buy bulbs before ill probs give these a go Enquired about a loom but didnt realize how much he wanted for a loom , there was a guy with a new loom company on here a couple of days or so ago with a loom for 30 quid , might try one of those Quote Share this post Link to post Share on other sites
vw rule 19 Posted October 3, 2013 Yeah as above they are really good bulbs got them in my head lights. I've got 60/55 watt in head lights. 100 watts in main beam spots. 100 watts in front fog lights. All this has made a real difference to my front lights big time, as they shine now a really bright blue / white, not the dim yellow / orange as standard. Or you can purchase the up rated wiring loom complete with relays, which is ment to be really good as well. Hope this helps. Si Quote Share this post Link to post Share on other sites
davidwort 0 Posted October 3, 2013 100w bulbs get very hot and will accelerate reflector damage if used regularly, I wouldn't use them without a set of relays on a loom tbh, apart from not getting the max from them with the voltage drop you get through vw's wiring and switchgear, you could get an electrical fire from the headlight switch which is weak anyway and definitely not designed for the extra current. Yeah as above they are really good bulbs got them in my head lights. I've got 60/55 watt in head lights. 100 watts in main beam spots. 100 watts in front fog lights. All this has made a real difference to my front lights big time, as they shine now a really bright blue / white, not the dim yellow / orange as standard. Or you can purchase the up rated wiring loom complete with relays, which is ment to be really good as well. Hope this helps. Si Quote Share this post Link to post Share on other sites
dragon green 4 Posted October 3, 2013 I use the Philips extreme vision,nice white light,but I have an uprated loom Quote Share this post Link to post Share on other sites
davidwort 0 Posted October 3, 2013 I use the Philips extreme vision,nice white light,but I have an uprated loom I use those too, both on an original vw setup and a relayed setup, they are a good improvement but really 'shine' with relays and at standard wattage they are both legal and cooler running Quote Share this post Link to post Share on other sites
vw rule 19 Posted October 4, 2013 Yeah cheers Dave I might purchase the after market wiring loom which ups the voltage slightly, but thought I'd try the bulbs first which I did years ago, and they seem to be bright enough as they are. I've got a new head light wiring loom and switch both from VW, the loom I think is still available from VW I've got the part number somewhere for it, if anyone needs it. I had the same set up on my old MK2 Scirocco years ago with those bulbs in the head lights, never had a problem with them. As long as you keep the standard wattage in the head lights i.e 60/55 watts you'll be fine. But don't put 100 watts in to head lights as they'll be too bright and will dazzle on coming vehicles, plus they may fail the MOT for being too bright. And as Dave has said they could weaken the contact in the head light switch, and melt the wiring loom (the head light loom) That's why I've kept the original wattage 55/60 in head lights. My 100 watt bulbs are only fitted to the main spots and front fogs, both of which are single element bulbs, plus these only come on when the main beam is operated, so there is no chance of blinding on coming vehicles. Plus they pass the MOT as well. And there's less chance of the switch contact melting as the main beam is only on for short bursts. The reflectors in the main spots & front fogs are heat resistant so should be ok. You never know there might be premature ware to them by using the 100 watt bulbs, but like I say I've had these bulbs fitted to most of my cars over the years, one of which was my Scirocco which I had for years, and they were all fine. Cheers Si :salute: Quote Share this post Link to post Share on other sites
vw rule 19 Posted October 4, 2013 Am I correct in saying there's someone on here who bought a batch of up rated head light switches, which don't break so easily as they're heavy duty so have stronger inners and don't course the wiring to burn away. I'm sure it was someone off here. I'll have a look in the search menu tomorrow or later on today should I say, lol. Si Quote Share this post Link to post Share on other sites
clumpy1 11 Posted October 4, 2013 8vMatt Mate. Quote Share this post Link to post Share on other sites
sexybourbon 0 Posted October 4, 2013 Iv already got a switch of 8v matt fitted to the car so all good there , im going to order an uprated loom for the lights today , so then i just need bulbs , cheers vwrule ill have a look at all the suggestions before i buy , i know this is a daft question then but how many bulbs actually go in to each light ? Is it one for main beam , one for full beam , one for side lights , and a seperate single bulb for the fogs ? Quote Share this post Link to post Share on other sites
davidwort 0 Posted October 4, 2013 H4 bulb in main reflector does dip and main (2 elements) then theres a single element bulb for the spot Quote Share this post Link to post Share on other sites
vw rule 19 Posted October 4, 2013 Hello Red, 100% as Dave has said above. Each head light unit has 3 bulbs in them (1, H4) (1, 233) (1, H3) H4 = dip & main (twin element) Plus 233 = side light (single element) One H4 is fitted in to each head light unit and the same with the 233 sidelight bulb. http://www.ebay.co.uk/itm/VW-90-Osram-H4-Night-Breaker-Plus-High-Low-Headlight-Bulbs-472-P43T-/300824848808?pt=UK_CarsParts_Vehicles_CarParts_SM&fits=Model%3ACorrado&hash=item460a8ee9a8 H3 = Front main spots and front fogs (single element) One H3 is fitted in to each head light unit and each front fog light unit. http://www.ebay.co.uk/itm/VW-VOLKSWAGEN-Corrado-88-95-Xenon-55w-Fog-Light-Bulbs-/190447356959?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2c578c0c1f Front indicator bulb (chrome plated inner coat) 382 (21 watt) (single element) This bulb shines a bright orange / amber so can only be fitted to the front or rear indicators only. One bulb per indicator unit. http://www.ebay.co.uk/itm/CHROME-FRONT-INDICATOR-BULB-TO-FIT-VW-Corrado-MODELS-382-P21W-/130975816780?pt=UK_CarsParts_Vehicles_CarParts_SM&fits=Model%3ACorrado&hash=item1e7ec45c4c Each front indicator unit has one 382 bulb, (21 watt) and the same for the rear indicator (single element) One bulb per side This bulb is also fitted in the reverse lights (again one each side) Plus one 382 is fitted to the rear fog light (one only) just the drivers side = O/S/R http://www.ebay.co.uk/itm/Volkswagen-Corrado-Front-Indicator-Bulbs-89-95-FI382-/400170200910?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item5d2c00af4e Each rear stop & side light has a 380 bulb (twin element) (21/5 watts) one is fitted to each rear light unit. http://www.ebay.co.uk/itm/2x-New-Genuine-Osram-Ultra-Life-Stop-Tail-Light-BAY15D-P21-5W-Car-Bulbs-/350888559129?pt=UK_CarsParts_Vehicles_CarParts_SM&fits=Model%3ACorrado&hash=item51b2968219 http://www.ebay.co.uk/itm/2-x-VW-CORRADO-1987-1995-BRAKE-STOP-LIGHT-TAIL-CAR-BULBS-380-/221276117084?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item338515985c Two 501 bulbs are fitted in the number plate light unit = each bulb is (single element) And one 501 are fitted in to the wing indicator each side, one on each wing http://www.ebay.co.uk/itm/2x-Osram-Original-Standard-Number-Plate-Light-501-W5W-T10-Bulbs-/350888556305?pt=UK_CarsParts_Vehicles_CarParts_SM&fits=Model%3ACorrado&hash=item51b2967711 Hope this helps. Si Quote Share this post Link to post Share on other sites
vw rule 19 Posted October 4, 2013 Thanks Clumpy1 that's great I'll give 8vMatt a shout. Thanks again :salute: Si :thumbleft: Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted October 4, 2013 I use the Philips extreme vision,nice white light,but I have an uprated loom Same. Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted October 4, 2013 Iv already got a switch of 8v matt fitted to the car so all good there , im going to order an uprated loom for the lights today , so then i just need bulbs , cheers vwrule ill have a look at all the suggestions before i buy , i know this is a daft question then but how many bulbs actually go in to each light ? Is it one for main beam , one for full beam , one for side lights , and a seperate single bulb for the fogs ? Dude I have a spare loom fs.... can let you have it at karting? Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted October 4, 2013 Can someone recommend me some good bulbs for the headlights Coming upto winter so need to sort out some decent lights Own up clio boy..... you don't have bulbs in hull ;) Quote Share this post Link to post Share on other sites
sexybourbon 0 Posted October 4, 2013 Thanks mr rule , brilliant info and links thats spot on , Your getting rammed off the track morris , seriously though cheers mate id of had it but iv literally just orderd one from that fancy new loom shop on the internet , will be in the post tomorrow , thanks anyway though mate Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted October 4, 2013 Thanks mr rule , brilliant info and links thats spot on , Your getting rammed off the track morris , seriously though cheers mate id of had it but iv literally just orderd one from that fancy new loom shop on the internet , will be in the post tomorrow , thanks anyway though mate Bring it big un! Quote Share this post Link to post Share on other sites
