LukeManic
Koni 8041 1108 on 1993 VR6
Hello,
I'm in the middle of replacing the rear suspension on my Corrado VR6 (1993). I made an attempt to build the shocks up today replacing the bump stops and bushes etc, I was then ready to fix the upper spring seat in place and feed the shock bar through it when I realised that the hole on the spring seat was too small. I had the original shocks on the car before which had thinner bars, has anyone else had this problem with Koni 8041 1108 and the original VR6 upper spring seats?
Many thanks,
Luke.
I found this when I fitted a pair to the rear of my 16v, I got them cheap of the bay and assumed the VRs had larger diameter threads.
I ended up drilling the holes out to fit
