timmaaah 0 Posted October 31, 2013 My heater direction control knob gear broke yesterday - I've got the bit of plastic that broke off - has anyone successfully repaired one of these gears? I was thinking about using superglue to hold the broken bit in, then filling in the big gap next to it with epoxy resin/J B weld. Anyone done this and has it worked? I'm also looking for a replacement non-broken one :) Quote Share this post Link to post Share on other sites
vw rule 19 Posted October 31, 2013 Hello there, here's the repair thread link below, should tell you everything you need to reair yours. http://wiki.the-corrado.net/late_heater_control_repair.html Hope this helps. Si Quote Share this post Link to post Share on other sites
bristolbaron 11 Posted October 31, 2013 superglue wont do the job as the slider pushes against the plastic as it turns. Mine had broken, but i had a spare broken control.. i used the spare plastic to plastic weld [well, push a bit of melted plastic around with a soldering iron] mine. The shape doesn't need to be perfect, but it does need to be properly strong. I guess you could used plastic from something else if you dont have a spare bit.. Quote Share this post Link to post Share on other sites
