leew 0 Posted April 17, 2003 I'm not sure if this is a problem or the norm but when i turn my ignition off after a decent run the radiator fan stays on. I know this is right but my fuel pump continues to run as well :? Is this right???? Quote Share this post Link to post Share on other sites
Scott 0 Posted April 17, 2003 I'm not sure if this is a problem or the norm but when i turn my ignition off after a decent run the radiator fan stays on. I know this is right but my fuel pump continues to run as well :? Is this right???? If its a 1.8 16V Corrado then yes this is correct - *:) *edit* - just seen you have a G60 - LOL *:) Not sure about the G60 but on the valver the reason this happens is that the fuel burns off when engine is hot (rad going) so the fuel pump keeps pumping until fan goes off to help the car start next time go to start it.... have the info somewhere... Quote Share this post Link to post Share on other sites
G60Jet 1 Posted April 17, 2003 Yeah the G60 pump fuel pump dies run on, to cool the fueling system to stop it evaporating Quote Share this post Link to post Share on other sites
leew 0 Posted April 17, 2003 Relief :D Cheers lads Quote Share this post Link to post Share on other sites
