wbx6dan 10 Posted April 13, 2014 hi i might be after a dash pod and indicator switch if available? Dan Share this post Link to post Share on other sites
Liam20vT 10 Posted April 14, 2014 Sold already. No problem, thanks anyway. Share this post Link to post Share on other sites
Liam20vT 10 Posted April 14, 2014 If you are after stock calipers, I have a set. Thanks Sean, I bit the bullet and bought one from Vw heritage as i use the car daily and had to be sorted on the weekend. All sorted now! Share this post Link to post Share on other sites
wbx6dan 10 Posted April 15, 2014 I have pmd re the dash and indicator switch Dan Share this post Link to post Share on other sites
G60MAT 0 Posted April 16, 2014 I have pmd re the dash and indicator switch Dan Replied. Share this post Link to post Share on other sites
Irishrob 10 Posted April 20, 2014 does the sunroof work? how much would you need for it? Share this post Link to post Share on other sites
dantiel 10 Posted April 20, 2014 hi if still got shell, im after the rear seat brackets removed/cut from shell floor plan Share this post Link to post Share on other sites
G60MAT 0 Posted April 21, 2014 does the sunroof work? how much would you need for it? Yes it worked, open to offers... Share this post Link to post Share on other sites
G60MAT 0 Posted April 21, 2014 hi if still got shell, im after the rear seat brackets removed/cut from shell floor plan Yes they are still on the shell... Share this post Link to post Share on other sites
dantiel 10 Posted April 21, 2014 Yes they are still on the shell... would you be willing to cut/remove these and post to bristol . i need the three for the back part of the split fold seat also the one the middle bit folds out (has first aid in )that also part of center colloum screws to . cheers Share this post Link to post Share on other sites
Irishrob 10 Posted April 22, 2014 Excellent. Can you send me your number please? I'm also in Cheshire so your not that far away. Share this post Link to post Share on other sites
GTi.Si 0 Posted May 7, 2014 Do you still have the fuel pump? Share this post Link to post Share on other sites
Afro Steve 0 Posted May 8, 2014 Hi, do you still have both front wheel hubs, if so how much for both posted? Cheers Steve Share this post Link to post Share on other sites
G60MAT 0 Posted May 12, 2014 Do you still have the fuel pump? Already gone. Share this post Link to post Share on other sites
G60MAT 0 Posted May 12, 2014 Hi, do you still have both front wheel hubs, if so how much for both posted? Cheers Steve Already gone. Share this post Link to post Share on other sites
sankysvr6 0 Posted May 12, 2014 Is the boost return pipe available? Share this post Link to post Share on other sites
G60MAT 0 Posted May 15, 2014 Is the boost return pipe available? Not for sale. Share this post Link to post Share on other sites
fabil 0 Posted June 13, 2014 I Have a USA style 91 Corrado and the front seat belt is the automatic model ( no works), I need to convert to euro style. Have you the complete front seat belts and plastic pillars cover? how much? Share this post Link to post Share on other sites
richman711 10 Posted June 15, 2014 Is the co pot sensor available? If so please pm me:) Share this post Link to post Share on other sites
Jamie 1 Posted June 15, 2014 Matt is the front bumper still about? ;) Share this post Link to post Share on other sites
G60MAT 0 Posted June 17, 2014 I Have a USA style 91 Corrado and the front seat belt is the automatic model ( no works), I need to convert to euro style. Have you the complete front seat belts and plastic pillars cover? how much? Yes still have them, £40 plus delivery at cost. Share this post Link to post Share on other sites
G60MAT 0 Posted June 17, 2014 Is the co pot sensor available? If so please pm me:) Not for sale Share this post Link to post Share on other sites
G60MAT 0 Posted June 17, 2014 Matt is the front bumper still about? ;) Its pretty damaged, you wouldn't want it. Share this post Link to post Share on other sites
Jamie 1 Posted June 17, 2014 Its pretty damaged, you wouldn't want it. Only want the numberplate recess mate if that's intact (I'm the man that drove up from London for the bonnet if you remember...) Share this post Link to post Share on other sites
clumpy1 11 Posted June 17, 2014 Jamie if Matt can't sort you out I have an early front bumper if you let me know what bit u require I'll cut it oot for u only Matt can't help. Share this post Link to post Share on other sites
