rodney
wheel bolt
hello
taken wheels off for first time to give a good clean. quite alarmed by how little thread is being used - compared to other cars i have owned. i have spoken to a couple of bods one of whom says you only need five turns when tightening (which i am def getting). the wheels are aftermarket 16 inch.
if anyone can put my mind at ease before i do a 450 mile drive in a few days i would appreciate it. :)
cheers
rodney
You need a bare monimum of 3 threads. there should be at least 5 or 6 in the hub, so use them. buy some longer bolts.
Couldn't tell you exactly how many turns there are on the standard wheel/bolt/hub set-up but I can tell you that subjectively it seems to be a lot more than just 5!!
thread on a VW wheel bolt is around 1.1mm per turn... 8)
(don't ask why I know that, it came up in conversation with a supplier a couple of weeks ago... ;) )
well, I'm afraid that's bullshit.
the thread pitch is 1.25mm IIRC? so that means the threads are spaced 1.25mm apart and for one turn, it'll move 1.25mm
