EJ Taylor
MORNING!!!! VDO Boost gauge, please read
so, ive just been paid (woohoooo) so its the monthly corrado spend, basically (no offence to anyone) but i think ALL of the boost gauges on the market look naff, just do not suit the corrado. One i have found is the 0-15 psi VDO gauge.
http://www.ebay.co.uk/itm/VDO-BOOST-GAUGE-BLACK-0-15PSI-52MM-TURBO-DIESEL-LANDCRUISER-PATROL-PAJERO-4WD-/120862674717?pt=AU_Car_Parts_Accessories&hash=item1c23fa0f1d
But, its in Australia, so before i spend £45 on postage, does anyone know of anyone closer to home that sells this? or similar VDO gauges? as all the vdo stuff im finding is in Australia.
Many thanks!!!!
yer thanks man!!!! i didnt realise they had it! rather pricey though isnt it! been hunting the web all morning haha. would be cheaper to buy it from Australia.
Thank you, appreciate it!
tread carefully with vdo's ive been through about 4 of em to get one i liked
firstly watch out as alot of them are electronic so you need a £60 sender to run it , and alot of them come bare so £12 add on for a bulb kit , another £15 for a hose and threaded ends , also make sure its not a fixed colour illumitaion
then next problem , i found one that i liked and it has some horrible plastic lense that never showed up in the photos , its like anti glare i assume but just looked greasy
in the end after much looking around i found a seller on ebay that does proper glass lenses and swapped it over , took the oppertunity to paint my needle while its apart
try ebay.de - search vdo ladedruckanzeige , at least theres no import tax from there
prob get stung import tax on that
plus with mods you might touch just over 15psi
i went with a bar one , what with germans being all metric n such lol
this is mine ..plus a new lense for £3 and a bulb holder
http://www.ebay.de/itm/VDO-Mechanische-Ladedruckanzeige-1-bis-1-5-Bar-Cockpit-International-52mm-12V-/350941240995?pt=DE_Autoteile&hash=item51b5ba5ea3
Yes see my stage 2 charger runs at 9 psi and I don't think ill ever sit it over 15. So I want it nice and accurate. A bar one just could be accurate enough. Only reason in getting it is to monitor the charger in case of belt slip. Yours turbo or changed? On iPhone so can't see your signature.
You see this is why I want to live in the states. Not only because of the fit birds and the flat roads. But look at there choice of everything!!!!!!
mines a golf g60 , 68mm pulley and it hits around 15psi / 1 bar
got mine for the same reason so i can see if something is up ...belt slip you would see lots of blask dust around the pulley
ah! thats good to know man! dont think ill be going near the 15psi mark, when i first fitted it and it was running at 5 it was lively, now sat at 9 psi its just an animal haha, if i hit 15psi i would be somewhere in the high 300's and f*ck that for a laugh... (for now anyway :cool:)
