Moreado 10 Posted July 3, 2014 Hello Do you have a driver side outer door handle? thanks Quote Share this post Link to post Share on other sites
Strugs 10 Posted July 14, 2014 Did the driver's seat go in the end? Quote Share this post Link to post Share on other sites
Blounter 10 Posted July 27, 2014 Have you still got the ABS light 535 919 235 BA 5 pin Cheers Quote Share this post Link to post Share on other sites
KipVR 1 Posted August 5, 2014 Looking for a vehicle speed sensor, screws onto the drive coming out of the top of the gearbox, part no. 191919149D, do you happen to still have it? Quote Share this post Link to post Share on other sites
StueyB 0 Posted August 18, 2014 tman2714 said: Hey, Don't know if you want to split the handbrake and gaiter from the rest of the tunnel but if you do, how much would you want for the handbrake and gaiter? Is it in the dark grey rather than black? Cheers, T Sold I'm afraid. Quote Share this post Link to post Share on other sites
StueyB 0 Posted August 18, 2014 Moreado said: Hello Do you have a driver side outer door handle? thanks Both broken. Quote Share this post Link to post Share on other sites
StueyB 0 Posted August 18, 2014 Strugs said: Did the driver's seat go in the end? Drivers seat sold as spares. Quote Share this post Link to post Share on other sites
StueyB 0 Posted August 18, 2014 Blounter said: Have you still got the ABS light 535 919 235 BA 5 pin Cheers Sold. Quote Share this post Link to post Share on other sites
StueyB 0 Posted August 18, 2014 KipVR said: Looking for a vehicle speed sensor, screws onto the drive coming out of the top of the gearbox, part no. 191919149D, do you happen to still have it? Sold with engine. Quote Share this post Link to post Share on other sites
logix42p 0 Posted September 22, 2014 hello, do you still have the distributor or did that go with the engine. Thanks Quote Share this post Link to post Share on other sites
Supercharged Will 10 Posted September 23, 2014 Do you have headlights? Quote Share this post Link to post Share on other sites
Supercharged Will 10 Posted October 1, 2014 Do you have a pair of late wings? Quote Share this post Link to post Share on other sites
dangeruss89 10 Posted October 9, 2014 Don't suppose you've got the VR6 ABS pump have you? Quote Share this post Link to post Share on other sites
StueyB 0 Posted October 31, 2014 logix42p said: hello, do you still have the distributor or did that go with the engine. Thanks Sold with the engine I'm afraid. Quote Share this post Link to post Share on other sites
StueyB 0 Posted October 31, 2014 Supercharged Will said: Do you have a pair of late wings? Supercharged Will said: Do you have headlights? Late Wings are being kept with the shell. Headlights as spares. Thanks. Quote Share this post Link to post Share on other sites
KipVR 1 Posted October 31, 2014 Parcel shelf supports? C pillar trims? Quote Share this post Link to post Share on other sites
StueyB 0 Posted November 5, 2014 KipVR said: Parcel shelf supports? C pillar trims? Pretty sure I can help with some C pillar trims. I'll check this weekend if you still require some. Shelf supports - one was badly broken. Quote Share this post Link to post Share on other sites
KipVR 1 Posted November 5, 2014 Yes please mate, I'll take a pillars too if they are still there? Quote Share this post Link to post Share on other sites
Christer Klovholt 10 Posted June 18, 2015 wire loom from fusebox to fuelpump with relay and fuel level sender in fuel tank? center console with ac button,ashtray and 12v cigarett lighter Quote Share this post Link to post Share on other sites
Gregor81 10 Posted June 18, 2015 Hi. Is the head lining any good? Sunroof motor still work? Quote Share this post Link to post Share on other sites
andyhudson 10 Posted June 22, 2015 You got a set of standard shocks and springs? Quote Share this post Link to post Share on other sites
StueyB 0 Posted June 23, 2015 Christer Klovholt said: wire loom from fusebox to fuelpump with relay and fuel level sender in fuel tank? center console with ac button,ashtray and 12v cigarett lighter All unavailable i'm afraid. Quote Share this post Link to post Share on other sites
StueyB 0 Posted June 23, 2015 Gregor81 said: Hi. Is the head lining any good? Sunroof motor still work? Sunroof was a mess and head lining damaged. Quote Share this post Link to post Share on other sites
StueyB 0 Posted June 23, 2015 andyhudson said: You got a set of standard shocks and springs? Shell is still currently sat on these and won't be for sale for a while. Quote Share this post Link to post Share on other sites
Grrrrallye 0 Posted June 24, 2015 Do you have the upper and lower radiator hoses available please? Quote Share this post Link to post Share on other sites
