diarmaid16
Breaking 1992 2.0 16v
hi do you have the sunroof/interior light wireing loom? i just need it cut from main wire that leads to fusebox please. inclusind light plugs and sunroof switch plugs thanks.
Hey man ,
I'm after some little parts for my corrado can you help ?
If you open your fuel flap , there's a rubber seal thing that goes round the bodywork ? I need that as mines go missing since being painted . Also , in the same place there's a piece of trim plastic I think , that goes into a square when the fuel fla is shut ? It holds it up a bit to align with the body work .
Hope that makes sense !
Just seen this, excellent! Please PM details and I'll send the money over :)
Do you have the two air duct panel things that attach to ether end of the splitter and connect to the wheel arch liners?
Ya, still have them. Should be ok, they're still on the car. Can check them tomorrow evening.
Have you had a chance to remove/check these?
