Alty
G60 Clutch flywheel package ?
Can anyone recommend a G60 Clutch and flywheel package ? I've been looking through our good friend Google and prices are one extreme to another so need some advice please.
I use my Corrado every day so I don't want an heavy track day clutch or anything but.... i however like to give the car some stick so would want something that is a little tougher what i believe to be a standard one...
If the price is right i may also grab a new gearbox well a different gearbox, VW Golf mk3 TDi CTN gearbox.
Just get OEM, with a new lightened flywheel.
Go new for the flywheel because a new clutch will bite harder on a new flywheel because it will be properly flat, without lumps and bumps worn into it by the pressure plate.
Send it to someone and get it taken to about 6KG, which will give you sharper throttle response and make the motor more rev-happy..
