shaft69 10 Posted January 5, 2014 (edited) Want replace supercharger belt has small rip in it. Just ordered new 12mm strengthen one is it easy enough to do? Can't find anything on repairs for it. Edited January 5, 2014 by shaft69 Quote Share this post Link to post Share on other sites
owen g60 10 Posted January 5, 2014 It's a relatively simple job to do. Remove the main pulley from the charger, remove the small belt cover. Remove and replace the small belt. Fit pulley and belt cover. Quote Share this post Link to post Share on other sites
shaft69 10 Posted January 5, 2014 owen g60 said: It's a relatively simple job to do. Remove the main pulley from the charger, remove the small belt cover. Remove and replace the small belt. Fit pulley and belt cover. Do they have to be aligned in anyway or just off and on. Quote Share this post Link to post Share on other sites
16VG60 1 Posted January 5, 2014 Hi, Am happy to help you with the info you require to enable fitting of your charger timing belt. We have specialised in Corrado G60 since 1993. It would be best for you,that I talk you through this process, as a wrong move in this area will potentially end game your charger. The task is not difficult , but needs to be carried out correctly. If you contact me at my workshop on Monday, I will explain the process and leave you with clarity on this procedure. Call me at JMR Ltd West Sussex , 01903 718684, or 07974020031. I look for wake to hearing from you. Bess regards, John Mitchell JMR Ltd Littlehampton West Sussex Quote Share this post Link to post Share on other sites
shaft69 10 Posted January 5, 2014 16VG60 said: Hi, Am happy to help you with the info you require to enable fitting of your charger timing belt. We have specialised in Corrado G60 since 1993. It would be best for you,that I talk you through this process, as a wrong move in this area will potentially end game your charger. The task is not difficult , but needs to be carried out correctly. If you contact me at my workshop on Monday, I will explain the process and leave you with clarity on this procedure. Call me at JMR Ltd West Sussex , 01903 718684, or 07974020031. I look for wake to hearing from you. Bess regards, John Mitchell JMR Ltd Littlehampton West Sussex Thanks john will give you ring tomorrow. Regards, kevin Quote Share this post Link to post Share on other sites
steveo29 0 Posted January 5, 2014 shaft69 said: Do they have to be aligned in anyway or just off and on. marks in the castings if i remmeber at 12 o clock on a clock face , deffo needs to be lined up rotate by hand and check again , theres no way to ajust the tension Quote Share this post Link to post Share on other sites
shaft69 10 Posted January 5, 2014 Was just going to mark pulley and casting on both remove and refit belt with mark same place. Quote Share this post Link to post Share on other sites
steveo29 0 Posted January 5, 2014 google images "g60 timing belt marks" shows a few , the marks are pretty obvious in the case Quote Share this post Link to post Share on other sites
