shaft69
Replacing toothed supercharger belt
Want replace supercharger belt has small rip in it. Just ordered new 12mm strengthen one is it easy enough to do? Can't find anything on repairs for it.
Edited by shaft69
It's a relatively simple job to do.
Remove the main pulley from the charger, remove the small belt cover.
Remove and replace the small belt.
Fit pulley and belt cover.
Do they have to be aligned in anyway or just off and on.
Hi,
Am happy to help you with the info you require to enable fitting of your charger timing belt. We have specialised in Corrado G60 since 1993. It would be best for you,that I talk you through this process, as a wrong move in this area will potentially end game your charger. The task is not difficult , but needs to be carried out correctly. If you contact me at my workshop on Monday, I will explain the process and leave you with clarity on this procedure. Call me at JMR Ltd West Sussex , 01903 718684, or 07974020031. I look for wake to hearing from you.
Bess regards,
John Mitchell
JMR Ltd
Littlehampton West Sussex
  16VG60 said:
Hi,
Bess regards,
John Mitchell
JMR Ltd
Thanks john will give you ring tomorrow.
Regards, kevin
marks in the castings if i remmeber at 12 o clock on a clock face , deffo needs to be lined up
rotate by hand and check again , theres no way to ajust the tension
