Kempy
New or used lower rad hose 16v
Are they obsolete? Anyone making them? My valver is leaking and I've been advised its the hose.
Thanks
This is proving very difficult to sort.. Two hoses have been bought and they are both too narrow, what should the diameter be? Internal?
Thanks
Hello Kempy,
have a look on Ebay, item number 310827139167
bottom radiator hose OEM part n.o: 191 121 051E
£13.40 with free delivery.
Shows 4 are in stock.
link:
http://www.ebay.co.uk/itm/Radiator-Hose-Bottom-Vw-Golf-Jetta-Corrado-Passat-Gates-3113/310827139167?_trksid=p2047675.c100011.m1850&_trkparms=aid%3D222006%26algo%3DSIC.FITP%26ao%3D1%26asc%3D20181%26meid%3D4539551127462147622%26pid%3D100011%26prg%3D9057%26rk%3D3%26rkt%3D10%26sd%3D400610531881
Or as the other guys have said AVS sell this hose as well,
their price is £9.90 takes 1 to 2 days for them to order it in,
their part number is 3113
States it fits none air con and manual trans Corrado.
AVS link
http://www.vwspares.co.uk/corrado_cooling.php
Hope this helps.
Si
Hello mate, cool fair play you've got one.
The bottom hose with part number 191-121-051E
this is normally used on most 4 cylinder 8v / 16v engines from the 1980s and 1990s
mainly MK2 / MK3 Golf and the Corrado.
Where as the top hose can be slightly different,
between the 4 cylinder 8v / 16v engines.
Part number 191-121-101P is for 2.0 8v (2E eng code - might fit ADY eng code as well)
This is a longer hose than the 16v one as the 8v engines sit back further,
so are closer to the bulk head but a little further away from the radiator.
Part number 191-121-101AC is for 1.8 16v / 2.0 16v (KR / 9A eng codes)
This hose is shorter than the 8v one above due to the way the alloy inlet manifold,
folds up and over the front side of the cylinder head,
so for this reason VW fitted a plastic triangle coolant housing,
that pokes through between the inlet manifold branches,
so making it a lot closer to the radiator.
Just found this link for future reference for anyone that needs it.
http://autopartmaster.com/en/?action=catalog_show&cat=vw&t_id=111258&added_=VOLKSWAGEN%20Scirocco/Corrado%201991
Hope this helps.
Si
Fairy urgent need one now. I'll try avs but I got a feeling it'll be too narrow again
That part number isn't the same as the part on etka/vagcat.
191121051E is the part number on parts catalogue, I've not got the hose, so I can't check the number on it.
