JAM11E
Sunroof Issue...not the normal.
I have recently purchased a sunroof as mine was broken (Sheared metal runner)
The problem is, the cable doesn't seem to pull the left runner/mechanism. Nothing looks broken. I am so confused, this sunroof is the bane of my life!
Any help would be appreciated
Could be many things. Check the springed latch on the left side to make sure it's not getting stuck in the grove - if it is, the cable may be a tooth out, or the rubber feet wear down, so replace these if it's a problem. The best thing to do is get it out of the car, take the panel off and operate the mechanism back and forth slowly (stop if you hit too much resistance) to see where there's anything broken, or anything getting stuck.If it's still no clearer, take out the cables and check them for wear, or if they may have snapped.
I've got a fully working mech from a MK3 golf if your interested just need to fit you sunroof panel from your C to the mech and away you go.
How much? I've currently spent £130 on sunroofs combines haha
