Bournemouth James 0 Posted May 23, 2004 The rear spring plattforms on my spax coilovers appear to be siezed on, they wont wind up or down They were on the car when i bought it, so i've got no instructions, but they are supposed to able to wind up and down whilest on the car right?...or am i missing something?, any ideas? Quote Share this post Link to post Share on other sites
dazzyvr6 0 Posted May 23, 2004 yeah they should,mine were pretty hard to turn,i would clean the threads as much as you can and soak them in oil Quote Share this post Link to post Share on other sites
Bournemouth James 0 Posted May 27, 2004 Need to get 2 new coilovers now...o dear Coated them in loads of wd40, then tryed the coilover spanner on them, wouldnt budge, then put part of an old exhaust pipe over the spanner for more leverage, all that did was rip chunks out of the plattform, and bent the spanner, So the only option i had left was to use some plumber stilsons (big ones) on them, and they are siezed on so much that ive atchully twisted the whole shock £299 for 2 rear spax coilovers.....o dear Quote Share this post Link to post Share on other sites
Bournemouth James 0 Posted May 27, 2004 pictures Quote Share this post Link to post Share on other sites
VR6 0 Posted May 27, 2004 Can you not buy replacement collars? Would be able to cut the old ones off, clean up the threads and then add the new collar. That's probably too simple though and if they were available, the new collars would be £300 a piece. Quote Share this post Link to post Share on other sites
Bournemouth James 0 Posted May 27, 2004 When you say collars, do you mean the spring plattforms? Dont think i can replace anything on them can i?, as the part ive twisted/bent is part of the whole damper? Quote Share this post Link to post Share on other sites
scruffydubbers 0 Posted May 27, 2004 had a simular problem with my avos, i ground the platform off and fitted some new ones, i was going to surgest this, then i saw your other pictures, looks quite nasty :? Quote Share this post Link to post Share on other sites
