jonnykillpop
New genuine VW 2.0 16V ISV 048 133455
[ATTACH=CONFIG]77306[/ATTACH][ATTACH=CONFIG]77304[/ATTACH][ATTACH=CONFIG]77301[/ATTACH][ATTACH=CONFIG]77302[/ATTACH][ATTACH=CONFIG]77300[/ATTACH][ATTACH=CONFIG]77300[/ATTACH][ATTACH=CONFIG]77300[/ATTACH]Bought this on Ebay having a punt it would fit a VR6, does physically fit but ticks over far too high so not using it. It is brand new and working, ran for 5 mins on my VR6, lad bought it off assures worked perfect on his 2 litre, ran for 20 mins in garage, and you can see it\s unmarked inside which backs him up.
Can't find any VW ones on Ebay but Intermotor ones which cheapest could find are 166 quid so I'll say 65 quid and got to be a bargain for someone.
Here's his Ebay description below.
"Here we have an Idle control/stabilisation valve that is for a 2.0 16v corrado , I bought this as I had an idle issue with my corrado but it turned out to be something else, so this has only been used for about 1 hour while the mechanic checked things over and then took it off so is as good as new.These are listed on ebay for £180 so you will get yourself a real bargain here as bids will start at £30 and there is no reserve.This will fit a 2.0 16v corrado with the OEM number of 048 133 455 (this is what is wrote on the box) .Any questions then just ask but bear in mind I'm not a mechanic and I'm only going on what I've been told,.UK only postage on this item."
(As a temp fix I put on a new Vauxhall Senator 3 litre 24v one which my mate had and works perfectly whilst was waiting for a VR6 one bought to arrive, different Bosch number and inlet slightly bigger, same size as outlet, hav'nt even bothered fitting VR6 one just kept as spare, so if can't find VR6 one try looking at Vauxhalls.)
Edited by jonnykillpop
I'll call dibs on this but will need to see some pictures. Are you 100% this is a OEM part?
My email Address is [email protected] if its easier to send picture to me that way.
Regards
Rory
I'll try and post up tonight when home, or send direct if can't, don't think I could figure out how to get a pic on this site last time tried.
The lad I got it off assures me he bought from VW and he took number off VW box, I never seen a 2.0 16v one in the flesh before, it's all black, same shape as VR6 one but not aluminium casing like them, inside seems to be different in that looks like plunger system rather than the slide valve thing the VR6 one has. It's clearly unused looking inside, save 5 mins on my car and 10 mins on his. Hopefully you can tell from photo's when send but any probs. if you buy it, just send it back and I'll give you money back if it's not right.
My neighbours got a Mk4 Golf GTI 2.0L 16V, (2003 I think) would this be the same? If so I can have a look at his and compare. Other neighbours got a MK1 Audi TT turbo, again can have a look at this if has same valve.
Yeh the 16v ones are all black. I'm sure it is the right one & if your happy to refund if it isn't correct then i'll definitely take it. the one on my car is ok but it has its moments so could do with one. My 16v is at JMR at the moment so john will know straight away if it's correct or not. PM me you details & i'll send over the money. when will you be able to get it in the post? (assuming you don't live in West sussex)
When I check the part number it didn't Bring up a golf as a car it could be fitted on.
Got pics on now see above before I saw your reply. It's clearly brand new looking at it so sure it'll be fine for your car, I'll PM you my details for payment and should be able to get in post same day, there's a Post office not far from home and work, I'm guessing Sussex is underwater is it? I'm from sunny Newcastle it's practically sub-tropical up here so never any weather issues.
Send me your name and address details please.
Cheers
Cheers Jonny, payment is sent:thumbleft:
Yeh there is quite a lot round here flooded but luckily now where I am. I'll pm you my address mate.
