Dox
How to - rear arch cuts from a donor shell
I've been doing a few shell cuts and having never done any before I didn't really know how to go about it. I removed the rear panel first which probably helps with the arches TBH
This is my second attempt having already done the drivers side for a practice I took pics to help anyone in a similar position
I found it easiest to sacrifice the whole quarter to allow easier access to the inner skin using the larger angle grinder
Once you've removed the section above there's just enough room to cut 80% of the inner arch from outside of the car with the small grinder (the chisel is just there to exaggerate the cut to show it more clearly
The cuts at the bottom of each arch are cut from underneath and inside the arch - the space saver gives a little more room, you may need to remove the wheel totally depending where your vertical cuts end at the bottom of the arch
You'll need both 9 and 4.5 inch angle grinders, a hammer and chisel to chop where the cuts don't quite meet and gloves!
Edited by Dox
I cut it all without doing that :smug: I'll post a pic 2moro I am a sheetmetal worker though.
Plasma cutter? I never took the wheels of and it could be done with the interior still inside. My shell has all sorts of crap thrown inside and a couple of inches of water too
I won't be doing it again, all safely tucked away in the garage loft - you never know when you'll need them :)
Bumper murderer! ;)
Lol it was knackered anyway
I bet there's one or two people who'd buy a bumper cut off you for a towing eye or exhaust cut out delete. Bumper iron if in good condition would be worth saving, they rot for fun
I'll check it to see cheer's Dox :thumbleft:
