Topcat147 10 Posted February 23, 2014 Hi, I have a set of Corrado Esoril Wheels that have a bad case of peeling lacquer. As a result there is some corrosion under he lacquer and I now need to get the wheels stripped to then resprayed. I've got quotes for restoring them but all way too much, so plan to so myself. So, onto my question.... As I do not have a sand blaster at my disposal, what product would you guys and girls recommend for stripping lacquer and paint off my alloys? I've been told that nitromors is an option, but have also seen some negative reviews stating it can cause bad pitting. Can anyone advise? Thanks all... Quote Share this post Link to post Share on other sites
fla 9 Posted February 23, 2014 i used nitromors on my tt comps and had absolutely no problem with it at all. They were in a really sorry state when i bought them. Quote Share this post Link to post Share on other sites
Topcat147 10 Posted February 23, 2014 Thanks! After stripping did you then just use wet & dry before priming and respraying? I appreciate your help! Quote Share this post Link to post Share on other sites
Goldie 2 Posted February 23, 2014 How much have you been quoted? Quote Share this post Link to post Share on other sites
Topcat147 10 Posted February 23, 2014 I was quoted £20 per wheel to simply blast or £50 per wheel to strip and powder coat. Quote Share this post Link to post Share on other sites
clumpy1 11 Posted February 23, 2014 Try Langlow Strip away pro. Quote Share this post Link to post Share on other sites
Topcat147 10 Posted February 23, 2014 Thanks Clumpy1 Quote Share this post Link to post Share on other sites
Goldie 2 Posted February 23, 2014 50 seems about the going rate, could you tie in a tyre change to make it more economical? Quote Share this post Link to post Share on other sites
Topcat147 10 Posted February 23, 2014 Tyres are decent and TBH I'm only restoring to then sell.... Quote Share this post Link to post Share on other sites
clumpy1 11 Posted February 23, 2014 Prep is the most annoying and most time consuming bit but do it right take your time and you will reap the reward's at sale time. Quote Share this post Link to post Share on other sites
Ruggy 10 Posted February 23, 2014 Whereabouts are you? I used a company in Bradford to do my Borbet C winter wheels. They only charge £1 per inch, so it only cost me £16 per wheel. This was to blast off the old black paint and then powdercoat them. Quote Share this post Link to post Share on other sites
