robrado974
Top handbrake section (oem fitting )
Can someone post a pic of the correct fitting please . My bottom section is fitted with daves handbrake solution , but the fixing point for the top section is slightly broken . I have tried to use a piece of metal similar to the headlight fixing only smaller, to join the two pieces together , but after 40 minuets of struggling to get my fingers in there and put a screw in it at the same time I gave up ! Thanks
Rob
Hi Jim ,i should be in possesion of my bentley manual soon . The bit im on about is as follows . The first section of the hanbrake tunnle sits on the carpet , the second bit that sits on top is connected at the back by the armrest hump .On the front near the end where it screws onto the first section is the pic im looking for . My bottom section has a piece of plastic missing , just wondered how the two are fixed together from the factory ?
Rob
