sankysvr6 0 Posted April 8, 2014 I am in the process of removing my charger to repair an oil leak, and I was thinking of replacing some of the bolts that I have taken off for marine grade stainless steel ones. Would there be any problems in doing this? it will be only the bolts that hold the charger to the brackets and some of the pipe work. The original bolts are only torqued to around 18ft/lbs. Quote Share this post Link to post Share on other sites
fla 9 Posted April 8, 2014 cant see an issue with stainless bolts on low load areas. Key areas include suspension bolts, perhaps engine mounts & bumper bolts, rear axle and others that require a decent amount of torque to tighten up. Quote Share this post Link to post Share on other sites
sankysvr6 0 Posted April 9, 2014 Makes sense, thanks. Quote Share this post Link to post Share on other sites
