MZpog 10 Posted April 8, 2014 Been doing a bit of spannering tonight and noticed a small blue plug at the right hand side of my fuse box. It has a single white/blue wire to it but nowhere obvious for it to plug. Anyone know what it is? Quote Share this post Link to post Share on other sites
paddy26 3 Posted April 8, 2014 There are a number of unused plugs at the back of the fusebox so it could be one of those. Can you trace it back to a pin on the fusebox or wherever it's going? Quote Share this post Link to post Share on other sites
slot 0 Posted April 8, 2014 I wouldn't worry about that Blue/White ! Unless your fitting a Diesel and planning on using the preheater light on your clocks. ? Quote Share this post Link to post Share on other sites
MZpog 10 Posted April 8, 2014 I wouldn't worry about that Blue/White ! Unless your fitting a Diesel and planning on using the preheater light on your clocks. ? No plans to turn the corrado into a tractor, lol Quote Share this post Link to post Share on other sites
slot 0 Posted April 9, 2014 Although you've just given me a cracking idea for a intergrated shift light ;) Quote Share this post Link to post Share on other sites
science 0 Posted April 9, 2014 Been doing a bit of spannering tonight and noticed a small blue plug at the right hand side of my fuse box. It has a single white/blue wire to it but nowhere obvious for it to plug. Anyone know what it is? Sounds like its from vehicle speed sensor connector block. The 4 way block on top of the fuse box distributes the VSS feed, and is normally full, one of the plugs has an extension, I think this is your plug. Quote Share this post Link to post Share on other sites
Sean_Jaymo 0 Posted April 9, 2014 Depends on whether it is a white wire with a blue tracer on it or a blue wire with a white tracer. 2 different wires! The tracer is the thinner colour of the 2. Quote Share this post Link to post Share on other sites
MZpog 10 Posted May 21, 2014 [ATTACH=CONFIG]78646[/ATTACH]Bit of a delayed response, but this is a picture of the plug (to right of last fuse) which has a white wire with blue tracer from memory. Quote Share this post Link to post Share on other sites
Guest sam1990rhodes Posted May 28, 2014 is that what a fuse box is supposed to look like? mine has so much crap there that it doesnt sit properly :( Quote Share this post Link to post Share on other sites
Stonejag 10 Posted July 12, 2014 If you fit cruise control then it plugs into the cruise ECU harness, otherwise it just dangles unused. Really need to get my cruise install sorted, I've had all the bits for ages... Try not to get it caught on anything, as if you ground it out the spoiler will stop working. Stone Quote Share this post Link to post Share on other sites
