Grum21 10 Posted April 11, 2014 Hi I've brought some borbet a's for my g60 7.5 on front and 9 on rear with flat center caps, But fitted rears today and found the stub axels sit to far into alloys for center cap to fit!! The wheels are on edge of arch so if get spacers then will be outside arch and as I understand illegal, The question is can I cut the stub axels down? I need to take bout 8mm off them so would had do away with the cap and re drill split pin hole. Is this ok? Or is there another way round it?? Thanks Quote Share this post Link to post Share on other sites
STU175 0 Posted April 11, 2014 that sounds strange, ive got same wheels on my g60 and not had a problem only difference is ive got the other "fake nut" style caps??? Quote Share this post Link to post Share on other sites
owen g60 10 Posted April 11, 2014 I've had these wheels fitted to my g60 previously with flat caps and had no issues Quote Share this post Link to post Share on other sites
Stonejag 10 Posted April 15, 2014 Take the cap off the hub? It's just a dust cover...or squash it a bit flatter. Wheels can protrude from arches up to 30mm provided no tread sticks out past the arch - but traffic police don't often know this so the further you go the more likely you ate to get pulled. Make sure your suspension has enough travel that the sidewalls won't hit the bodywork, or all bets are off... Stone Quote Share this post Link to post Share on other sites
