GlosterOx 0 Posted April 14, 2014 Found out last night that the tailgate does not lock with the same key as all the other locks - Can it be retumbled? Ian. Quote Share this post Link to post Share on other sites
dragon green 6 Posted April 14, 2014 Yes,I did mine a few years ago ! Quote Share this post Link to post Share on other sites
Stonejag 10 Posted April 15, 2014 Yep, hand to change the barrel on mine as it was full of road crap and I couldn't get the key in! Pop off the arm from the central locking actuator, then two bolts to remove. Bit awkward removing the barrel, you have to press the button in and simultaneously remove the small brass retaining cross pin at the back. With the pin out you should be able to wiggle it free with the right key inserted. If you don't have the right key you''ll have to pick it... Not worth doing unless you're going to replace the rubber seal at the front of the barrel at the same time, otherwise it'll just lock solid with road dirt before you know it. Might be worth checking this hasn't happened with a good squirt of WD40 before getting too into it! Stone Quote Share this post Link to post Share on other sites
GlosterOx 0 Posted April 16, 2014 Yep, hand to change the barrel on mine as it was full of road crap and I couldn't get the key in! Pop off the arm from the central locking actuator, then two bolts to remove. Bit awkward removing the barrel, you have to press the button in and simultaneously remove the small brass retaining cross pin at the back. With the pin out you should be able to wiggle it free with the right key inserted. If you don't have the right key you''ll have to pick it... Not worth doing unless you're going to replace the rubber seal at the front of the barrel at the same time, otherwise it'll just lock solid with road dirt before you know it. Might be worth checking this hasn't happened with a good squirt of WD40 before getting too into it! Stone Thanks Stone, very helpful - Any idea on the Part Nr for the Rubber Seal at the front of the barrel? Ian. Quote Share this post Link to post Share on other sites
