robrado974 1 Posted April 27, 2014 I know the corrado isnt the best at getting rid of rain water , after a wash it takes an age to dry it . But after re charging my battery i was shocked at the amount of water in the battery tray area when i went to fit the battery back in . The channel which holds the wiring was near on 20mm deep in water , ive never seen it that bad before . Has any body done anything to relieve this ?. I have surface rust in this area already and im worried that with this much water sat in there any one time it rains its going to make matters a whole lot worse . Kind regards Rob Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted April 28, 2014 I recently cleaned all my tray area up and found some blocked drain holes that ive since freed up. Some at the front some at far os near rear mount slide thing. Im surprised much is getting in there come to think of it mate.... do you have front seal on your bonnet? Quote Share this post Link to post Share on other sites
robrado974 1 Posted April 28, 2014 Thanks mate , I will have a look at the rear drainage holes . As the the seal yes it's fitted . Rob Quote Share this post Link to post Share on other sites
