Azrael
ABS light constantly on
Hello forum,
I'm having issues with my restoration project, a 1990 G60, the issue is that the ABS light is constantly on. I've already checked the fuses, relays, and the wheel sensors, which all gave me approximately the same values and fluctuated similarly, when giving the wheel a spin, except for one which seemed to hit a higher number of resistance then the rest.
Here's hoping someone can lend me a hand with this issue!
Thanks in advance,
Roland.
It really needs to tested using the Vagcom . This will tell you exactly what's doing what with the Abs .
Rob
Ahh, I forgot to mention I did try to get the ABS errors read by the dealer however the tester said there was no plus on the diagnostics port, tried some different methods to get blink errors but none worked so far. There's a black and a white connector with the black one having a + and ground and the white one having a +, I did see the ABS light dim slightly for an instant when I connect the white + to ground but no error codes so far.
