hutchison1985
What sunroof fits corrado's
Hi guys I was told passat b4 Mk4 sunroof fits corrados. I just went and bought the glass and it does not fit as its too short width wise. It cam out an N reg passat and mine is an N reg corrado.
My sunroof has now broken and I want to replace the whole unit. I am after a glass sunroom to lighten up my inside. Does the mk3 sunroof system work or any audi's etc. Help needed asap for show this weekend.
B4 won't fit. B3 can be used for swap of broken runners. Best fit of glass sunroof is seat ibiza 95-98 or something from that model. MK3 will fit but is more rounded that flat corrado sunroof.
Just been to a local breakers today in search of a sunroof, and allI could find was a late 90's SEAT Ibiza with a manual sunroof. Would one of these work in a Corrado?
I used one of those in my old corrado
So was it a straight fit? And did you retain the manual winder, or does the motor fit up to it? Cheers. :)
Yeah, it bolted straight in and the motor spline fits perfect into the manual winder hole so easy to swap :)
