JAM11E
Sump pan hex/Allen bolts...where?
Hi guys,
Where can I get the Allen/hex bolts that fix the oil pan to the underside of the car?
If they are available from VW does anyone have the part number?
Thanks
I replaced mine with St/Steel bolts + washers recently from a fastener wholesaler locally, other than that I would guess they should be available from VW?
Ian.
They are available from VW. Part number N90423402, you will need 25 or 25 (can't remember). It came to £18 for me, but that was with a decent discount from a friend at TPS.
The design has changed from allen heads to standard bolts. Access is a bit tight with a socket where the sump meets the flywheel so I used a few of my old allen bolts for this.
Ouch, think my stainless ones were about £3 or £4 total including washers - No one is going to see them and at least they won't rust!
Ian.
Ian.
Do you remember what thread size etc they were?
  VAG-hag said:
M6x14 cap head should do the job. Im off bolt shopping this aft if you want me to grab some?
I have an oil leak because I bashed my sump so I need to do it tomorrow, I ordered from Vw.
Thanks all the same though
Just about to do mine... Do I need washers for the cap heads ? If so normal flat or spring washer
I'm been lazy I,ve not looked under the car yet.
I would use washers if you are using normal cap heads with no flange. Or as I did, clean up the old vw ones and reuse them
