ChrisL 20 Posted June 8, 2014 (edited) 1996, N reg - 68500 miles with FVWSH and original factory Blackberry paintwork. I bought the car from Bill Aitken in 2011 and he owned the car since 2000. Since owning it I have completely stripped the underside and powder coated and re-built it to an extremely high standard. Spec as follows: INTERIOR Black leather interior with electric heated Recaro front seats Factory option gauge pod with voltage and oil pressure New gearknob Kenwood Mask single CD player but also includes an Alpine head unit with 6 cd changer, 2 Alpine V12 amps driving front MB Quart component speakers and Alpine 10” bass sub housed in a custom made boot install Cobra Category 1 Thatcham approved alarm BODY Custom red tinted rear lights Clear side repeaters All black badges Remanufactured factory spec dealer number plates Powder coated petrol tank straps Heat shields all vapour blasted EXHAUST Supersprint cat back system with both rear boxes in stainless steel New genuine VW exhaust hangers SUSPENSION H&R Height adjustable suspension – re-plated and powder coated springs Bonrath uprated suspension top mounts New front wheel bearings New bottom ball joints New drop links New track rods and track rod ends Powder coated bottom arms, subframe, driveshafts, hubs, radiator and engine support Powder coated rear beam All new genuine VW bolts, screws etc Factory speedlines blasted and powder coated BRAKES Black Diamond grooved discs all round with Pagid pads Powder coated backplates Stripped and painted calipers Goodridge braided rear brake hoses and genuine VW front flexis Re-manufactured original brake lines from bias valve forwards New bias valve New master cylinder reservoir New master cylinder to ABS pump pipes All new genuine VW bolts, screws etc ENGINE Painted block Powder coated sump with genuine new gasket New exhaust gaskets New inlet manifold gaskets New cam cover gasket Blasted and painted inlet manifolds New water pump Painted gearbox Cleaned and re-plated gearbox brackets and bolts New PAS pump New auxiliary belt tensioner Fully serviced with new oil filter, oil, water, PAS fluid, brake fluid Price: £7,000.00 on standard speedlines or £9,500.00 on new RS301's and Yokohama tyres contact: Chris Zero7816919833 Edited June 15, 2014 by ChrisL Quote Share this post Link to post Share on other sites
