ryan_welshman 10 Posted June 15, 2014 Ok guys, bit of an odd one, took one of the front signals out to demist the foglight lens, when I put it back together, that signal light wouldnt light up. I thought maybe the bulb had blown so I put bulb in the other front signal to test, now that one doesnt work once I put it back together. Now I have no front signals working now and I dont know why!! Help!!! Quote Share this post Link to post Share on other sites
Supercharged 2 Posted June 15, 2014 Check fuses mate :-) Quote Share this post Link to post Share on other sites
ryan_welshman 10 Posted June 16, 2014 Checked, they look ok Quote Share this post Link to post Share on other sites
Supercharged 2 Posted June 16, 2014 So what works and what doesn't?? Quote Share this post Link to post Share on other sites
ryan_welshman 10 Posted June 16, 2014 All other indicators work apart from the front ones. Also, the indicators flick faster than before on the side and rear, but go at normal pace when hazard button is pressed... Quote Share this post Link to post Share on other sites
Sean_Jaymo 0 Posted June 16, 2014 They flick faster as that's a built in system to tell you that a bulb is blown. I have this with my front left indicator, on mine this is down to a bit of a corroded bulb holder. Bit of a wiggle and all is well. The hazards flick at normal speed as a different relay controls them. Quote Share this post Link to post Share on other sites
ryan_welshman 10 Posted June 16, 2014 Ahh! Okie doke. Will have a wiggle later and try that! Cheers Quote Share this post Link to post Share on other sites
Hofmiester 10 Posted June 16, 2014 I had a problem in that the wiring on one side had been messed with by someone in the past who had fitted a new wing. The wire was chaffing on the bodywork and when I removed the bulb and replaced, it was resting in just the right place to short out. You'd have to remove your arch liner to check. Quote Share this post Link to post Share on other sites
ryan_welshman 10 Posted June 16, 2014 Yeh. I sorted it now. Just gave the bulb and plug a jiggle an its works :) Quote Share this post Link to post Share on other sites
Sean_Jaymo 0 Posted June 16, 2014 Nice when it's so easy! Quote Share this post Link to post Share on other sites
