stuarttaylor37 13 Posted June 22, 2014 Yesterday the coolant hose to the matrix split on my Vr Nothing obvious when its ticking over but when revved the split opens up and water shoots out. Would you expect the leak to get worse with an increase in revs ? I understand that the water flow rate would increase as the water pump rise with the engine speed but would this also cause an increase in pressure....or does it suggest head gasket failure/ Cheers Quote Share this post Link to post Share on other sites
Sean_Jaymo 0 Posted June 22, 2014 It just suggests old hose, Nothing suspicious there :) Quote Share this post Link to post Share on other sites
stuarttaylor37 13 Posted June 22, 2014 Thanks Sean Quote Share this post Link to post Share on other sites
Sean_Jaymo 0 Posted June 22, 2014 *No warranty is implied Hope you get it sorted easily and cheaply :) Quote Share this post Link to post Share on other sites
stuarttaylor37 13 Posted June 22, 2014 Ordered a Meyle one from KMS for £24. Will fit it on Tuesday Quote Share this post Link to post Share on other sites
Sean_Jaymo 0 Posted June 22, 2014 Easy fix :) Give the system a flush and a top up with G13 whilst you're there and you should be good for a couple of years bar any more split pipes! Quote Share this post Link to post Share on other sites
stuarttaylor37 13 Posted June 22, 2014 Got a rad to fit at the same time as thats weeping too! Quote Share this post Link to post Share on other sites
clumpy1 11 Posted June 22, 2014 Car will have you weeping Stu sooner or later ;)...... They all do!! Quote Share this post Link to post Share on other sites
Sean_Jaymo 0 Posted June 22, 2014 Best change the whole lot while you're in there then, it would be very frustrating to change bits and bobs and have something else go pop a week later! Unfortunately, that's an expensive little job! Quote Share this post Link to post Share on other sites
stuarttaylor37 13 Posted June 22, 2014 clumpy1 said: Car will have you weeping Stu sooner or later ;)...... They all do!! This happened after fixing the ARB drop link on Saturday- I was ready to leave it in the woods with a lit candle on the backseat! Quote Share this post Link to post Share on other sites
clumpy1 11 Posted June 22, 2014 Sean_Jaymo said: Best change the whole lot while you're in there then, it would be very frustrating to change bits and bobs and have something else go pop a week later! Unfortunately, that's an expensive little job! Expensive yes but in the long run could save you money if anything else decided to give up soon Quote Share this post Link to post Share on other sites
