Tigerfish 10 Posted July 1, 2014 How much play should there be in the gearbox end with the balance weight? The gear changes are OK, i.e. I can get all gears ok, but there is a fair bit of sloppiness in the gear stick end. The linkage at the gearbox end, the one with the balance weight, wobbles all over the shop, should it do that? Quote Share this post Link to post Share on other sites
Mr_Rossy 0 Posted July 2, 2014 Mine is the same as yours too, I've found that the actual shifter (The gear stick) has play at the bottom. The way for find this is to feel down the shaft (This isn't porn) and try to slide the shaft left nad right from the bottom. mine moves about 1-2cm!!) I've ordered a new short shift from Dave16v for £45 in the hope that this will cure the problem (I'd be shocked if it doesn't) Cheers M Quote Share this post Link to post Share on other sites
g0ldf1ng3r 17 Posted July 2, 2014 Mine is the same as yours too, I've found that the actual shifter (The gear stick) has play at the bottom. The way for find this is to feel down the shaft (This isn't porn) and try to slide the shaft left nad right from the bottom. mine moves about 1-2cm!!) I've ordered a new short shift from Dave16v for £45 in the hope that this will cure the problem (I'd be shocked if it doesn't) Cheers M Good move Mr_Rossy! i used to have issues with 2nd to 3rd changes when on full throttle but since fitting one of daves short shifter i no longer occasionally have a crunchie :D im definitely getting one for the gf's storm & another for my valver when funds allow Quote Share this post Link to post Share on other sites
Mr_Rossy 0 Posted July 22, 2014 I found that mine was caused by the C clip missing off the end of the shaft! I've now got a spare short shift for sale / or return to Dave. Matt Quote Share this post Link to post Share on other sites
fendervg 33 Posted July 22, 2014 Also check the engine and gearbox mounts as these can lead to sloppy shifting if worn. Just had mine replaced and made a huge difference. There is a special tool from VAG for aligning the gearshift lever, but most mechanics do it by feel. - I have one, so if anyone in Ireland wants to use it, PM me. Quote Share this post Link to post Share on other sites
Tigerfish 10 Posted July 22, 2014 Thanks for the tips guys. Will take another look and see what's what. Quote Share this post Link to post Share on other sites
