awigman 0 Posted July 14, 2014 I have zero life in the heater blowers. They do not turn on at all. Iv checked the fuse which seems to be fine. What else could it be/ worth checking Thanks Quote Share this post Link to post Share on other sites
davidwort 0 Posted July 14, 2014 did you check the thermal fuse on the resistor on the side of the motor - see the how-to-guide to check the motor itself, simply remove it and short it straight to a 12V battery to see if it spins, hold on tight though :) Quote Share this post Link to post Share on other sites
MarkB 10 Posted July 14, 2014 Check the fan knob is on the right one, it has a special cut out in it. If not it pushes the contacts off the panel and doesn't work. Quote Share this post Link to post Share on other sites
