awigman
Heater/Blowers not working.
I have zero life in the heater blowers. They do not turn on at all. Iv checked the fuse which seems to be fine.
What else could it be/ worth checking
Thanks
did you check the thermal fuse on the resistor on the side of the motor - see the how-to-guide
to check the motor itself, simply remove it and short it straight to a 12V battery to see if it spins, hold on tight though :)
Check the fan knob is on the right one, it has a special cut out in it. If not it pushes the contacts off the panel and doesn't work.
