coolrado 0 Posted June 4, 2004 i recently noticed a knocking from my front right wheel when driving over bumps i jacked the car up and it seems to be caused by a worn shock absorber the shaft moves side to side in the strut slightly. the front shock absorbers seem to be an insert type (removable damper cartridge) is this correct :?: , or can they only be puchased as a complete unit :?: it would be better if i could just replace the cartridge as i would not have to get the camber and tracking done again. Quote Share this post Link to post Share on other sites
dr_mat 0 Posted June 5, 2004 Complete unit, assuming they're original equipment. They're about £35 from GSF. Replace both on the same axle at the same time. Yes you'll need to get the camber done again afterwards. May aswell replace the top mounts and top bearings too, while they're off. Quote Share this post Link to post Share on other sites
coolrado 0 Posted June 5, 2004 i think they are oem as the previous owner had the car from new and had everything done by vw dealers, but the strut tubes have an external thread at the top with a notched ring for a removal tool quite similar to my old mr2 ones. Quote Share this post Link to post Share on other sites
VR6 0 Posted June 5, 2004 Sounds like they are height adjustable then.... Quote Share this post Link to post Share on other sites
dr_mat 0 Posted June 5, 2004 Yeah, the OEM struts are sealed units, no adjustment, no screw threads, no notched rings (as it were). Quote Share this post Link to post Share on other sites
coolrado 0 Posted June 5, 2004 just took a couple of photos to show what my shocks look like. if they are not oem any ideas of what they are :?: Quote Share this post Link to post Share on other sites
Henny 0 Posted June 5, 2004 I could be wrong, but they appear to be MKII Golf struts with inserts... :? (euro lists 'em as Bilsten items for MKII Golf anyway... ) Looks like someone may have swapped a set of suspension over at some point.... :? Quote Share this post Link to post Share on other sites
coolrado 0 Posted June 6, 2004 would this cause any problems :?: am i better off replacing them with a new set of corrado ones from gsf :?: Quote Share this post Link to post Share on other sites
Captaincook 0 Posted June 6, 2004 I would change them for corrado ones, at least then you know they are the right ones for the car, from GSF they are only £35 per side, and because you are changing them anyway you might aswell put the right ones in. Quote Share this post Link to post Share on other sites
coolrado 0 Posted June 7, 2004 are these the right ones for a 1991 g60 45560 SHOCK STRUT BQ GAS FR CO All Ex. VR6 £42.50 X2 45709A STRUT TOP MOUNTING CO 4 Cyl >7/94 £9.50 x2 they dont seem to list a bearing for a 91g60 ?????? are they included in the top mounts????? or would i be better off getting the bilstein ones from euro ?? about the same price. Quote Share this post Link to post Share on other sites
Captaincook 0 Posted June 7, 2004 where are those prices from. They could be different because mine is a VR6, I never checked the prices for other models. I bought my front shocks 2 weeks ago and they were only £35 per side. The top mounts came in a kit for 11.85 included was the rubber bush and the bearing it worked out about a £1 cheaper buying the kit. Quote Share this post Link to post Share on other sites
coolrado 0 Posted June 7, 2004 the prices are from gsf the g60 ones do seem more expensive than the vr. and they dont seem to do a top mount kit for a g60 confusing :roll: Quote Share this post Link to post Share on other sites
Captaincook 0 Posted June 7, 2004 im sure the bearing is the same, ive heard that the VR6 bush is better, as in it lasts longer, ring them see what they say Quote Share this post Link to post Share on other sites
coolrado 0 Posted June 9, 2004 just done a search on the forum to try and find out more about the standard shocks and it seems that a few people have had problems with sachs/boge units, too spongey, body roll ect is this just with vr's or would they be ok on the g60? where is the best place to get the bilstein items ? what comes with the "suspension kit" from gsf? ive got the mot coming up in 2 weeks time and i think its going to fail on the shocky :( so i need to order a pair soon. Quote Share this post Link to post Share on other sites
dr_mat 0 Posted June 9, 2004 There's nothing wrong with SACHS/BOGE gas shocks - they are the same as was fitted at the factory (on the VR6 at least). That may be too soft for some people, but that's a personal decision. The car that won all those motoring press plaudits was equipped with SACHS Advantage shocks, so they can't be all bad. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted June 9, 2004 I think Eurocarparts sell Bilstiein... Quote Share this post Link to post Share on other sites
coolrado 0 Posted June 9, 2004 im sure the bearing is the same, ive heard that the VR6 bush is better, as in it lasts longer, ring them see what they say anyone else upgraded to vr6 top mounts are they the same ? Quote Share this post Link to post Share on other sites
Andy T 0 Posted June 9, 2004 Euro car parts still list 'Bilstein' shocks for the C, but when they arrive they are BOGE items! I tried 3 times and the result was always the same. http://www.motorsportworld.co.uk sells Bilstein OE shocks at a price cheaper than ECP, mail order. I thought VR6 top mounts are more comfortable than the 4 cyl. top mounts, but that the suspension will sit 10mm higher?? I got the 4cyl. top mounts from GSF for my G60, and they were exactly the same genuine part as the original factory items :) Quote Share this post Link to post Share on other sites
MoonlightVR 0 Posted June 9, 2004 Yep, Bilstein are available thru Euro car parts. VR top mounts are stronger than G60/16V parts and so ideally suited to cars fitted with uprated suspension kits/coilovers. If you're sticking with OE spec suspension it's probably not worth upgrading. If you chose to go with VR top mounts you'll need to buy all the other components too ie. bearing and retaining nuts etc Best to check the parts from an exploded diagram in Ekta. Quote Share this post Link to post Share on other sites
coolrado 0 Posted June 11, 2004 just ordered new shocks from avs quite a bit cheaper than ecp or gsf 8) the bushes look like the original ones and are probably knackered, will the bugpack ones for the mk2 golf fit i know the steering rack ones and the rear axle ones are wrong but if i order the total kit i can flog the rest of the bits on e-bay (a mate of mine did this with his golf as some of his had allready been upgraded he sold the bump stops, rear axle bushes and rear top mounts and made enough money to pay for the whole kit) 8) Quote Share this post Link to post Share on other sites
Captaincook 0 Posted June 11, 2004 Coolrado, Who are AVS and ECP. Quote Share this post Link to post Share on other sites
coolrado 0 Posted June 11, 2004 Coolrado, Who are AVS and ECP. avs= audi vw spares, i think http://www.vwspares.co.uk/ ecp=euro car parts Quote Share this post Link to post Share on other sites
Andy T 0 Posted June 11, 2004 Which bushes are shot? Bugpack = cheap shite upgrades for beetles and the like, don't bother, just get quality standard bushes :) AVS are great, good prices and quality parts :) Quote Share this post Link to post Share on other sites
coolrado 0 Posted June 11, 2004 Bugpack = cheap shite upgrades for beetles and the like, don't bother, just get quality standard bushes :) i thought polyurethane was stiffer and much longer lasting than rubber couldnt really see the difference between the powerflex bushes my mate had on his golf allready and the new bugpack ones apart from the colour and the fact the bugpack ones use normal steel sleeves instead of the stainless ones in powerflex bushes and they definately improved the handling and feel of his car Quote Share this post Link to post Share on other sites
Andy T 0 Posted June 12, 2004 Yeah powerflex bushes are good, properly engineered kit, I just don't like Bugpack stuff it's cheap (but alright for aircooled vw's that don't handle anyway) Powerflex claim they don't increase noise/vibration over standard bushes, but they do, especially when combined with uprated springs/shocks/engine mounts/low profile tyres, it becomes really noticeable. Just depends how far you go and whether you mind a harsher ride/feel. I definately would not use aftermarket/poly bushes in the rear axle of corrado's/golfs with passive rear wheel steer, it's going to spoil the handling. Even in this months PVW magazine, Mr Wotsit from Awesome GTI advises that poly axle bushes can be fitted instead of OE items, and that they will increase rear tyre wear(as if its a plus point!!) IMHO some parts of VW engineering just shouldn't be messed with :roll: Quote Share this post Link to post Share on other sites
