stuarttaylor37 13 Posted July 22, 2014 I got in the car yesterday no windows working, on the way home both sides working again This morning the same and working on the way home again. I'm guessing at possibly a faulty relay? Does anyone know which one it is or what else it controls? (if anything so I can check that as well) Cheers Stuart Quote Share this post Link to post Share on other sites
daves16v 1 Posted July 22, 2014 Stu, I have intermittent windows but my problem is the switch, probably had water ingress in it's time. Dave Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted July 22, 2014 Does it work from passenger side? I can't remember if you can swap the switches over on a corrado but that can be a good way to diagnose a fault. Also worth pulling the fuse out and seeing if it needs a clean. Could be a dodgy bit of wiring in the door hinge area. Wiggling wires while trying the switch can show up bad connections. Even just unplugging connections and reconnecting them can solve s problem. Quote Share this post Link to post Share on other sites
stuarttaylor37 13 Posted July 22, 2014 daves16v said: Stu, I have intermittent windows but my problem is the switch, probably had water ingress in it's time. Dave Cheers Dave Not sure if its the switch because it effects all three switches at the same time Quote Share this post Link to post Share on other sites
