delfinis38
Arcan jacks
Are the arcan jacks still getting a big thumbs up....
Just about to buy only really looked at SGS and arcan. But like the look of the arcan with the red anodised body....
Any other suggestions.
Assume 1.8t is fine for most standard road cars.
Yup just been looking.. I'm not a member but looks like 5% extra if I order online as a none member.
It seems a lot cheaper than the identical Clarke from machine mart.
my only put off is the one i wanted from SGS was a super low jack which at its lowest is 7cm compared to 8.9cm on the arcan on. Cant see 2cm making too much ill measure up this weekend
If it's the ultra low profile one it weights is 40kg. Thought it was a bit too heavy to shuffle around. Both the equivalent sgs and the arcan weight about 25kg
Edited by delfinis38
Where are you based? I live about 2 minutes from the Costco in Coventry and would be happy to pick one up for you and hang onto it till a meet or whatever.
My car isn't exactly 'rubbing on double yellows; but is low enough and the Arcan fits underneath with no issues..
I got mine quite recently and its a much improved design on the old one i had. The new one is a twin piston 1.8 tonne lifter and so far so good..
Same offer from me if anyone needs to visit Costco i have a card..
I can meet people at Sheffield or leeds costco if it helps folk out
Cheers jim vag-hag and goldie only if you were a bit further south....
My local one is Watford or Milton Keynes.
May just pay the etra 5% from website for non member.
Looks like decision made....
Now for what axle stands thread :)
arcan stands are very sound too, way over strong for our lil coupes
With the Arcan make sure you undo all the bolts and put some thread lock on them as they will work loose! Other than that there a fantastic Jack.
I've been looking for the arcan website...
Are the jacks made to a British standard. Reason I ask as I've never heard of them before
Mmmmm big box just turned up with arcan jack in it.......
thanks for all the info chaps.....
ordered direct from web.... paid extra £5 as I'm a non member and got free delivery.... I couldn't even drive to Costco for a £5
I'd be interested in how many pumps of the handle to raise to full height for the Alcan and SGS jacks please
Im going for sgs as its got 2 year warranty
2yr warrantee for what I use the jack for ain't a lot.... If I was using every day I could see the advantage..... I suspect I will only use it half a dozen times in 2 years. If it goes wrong I will just buy something else.... No complaints yet from rest of forum..... and by the time you parcel it up and sent it back to the manufacture... you might as well buy a new one....
Arcan suggests 5 with no load... To get to half metre.....
Not tried it though.
Equivalent sgs which 2.5 t rating.... 9 pumps to get to 460mm dunno if this is loaded...
delfinis - if you do have a fault costco customer service is great
cheers vag-hag..... I don't anticipate any problems..... looks very well made.
just primed the jack and removed the wire..... just about to lift the audi up to see if it works...
