jindle
ABS pump noise
Hello all, set off in 93 VR6, and noticed after around thirty seconds that the Abs light was still on. Hit the brakes to stop and they pushed back and the abs pump started make a very loud noise, as if it was stuck on.
Parked up and disconnected the battery now. Any ideas what it might be? A faulty relay perhaps?
Could be something like the pedal position sensor or a wheel sensor. Mine was all disconnected by a previous owner. ABS seems a bit sketchy on the corrado. I prefer a car without tbh.
Any clues as to where fuses and relays are? Can't find anything behind the globe box?
Have you taken the glove box out?
Hi mate, have found them now, they'd been tucked down under some wiring and foam.
Pulled the fuse attached to relay 179 and all good now.
Time to study some wiring diagrams I guess. Did notice some corrosion on the relay too but hopefully just a spider web interfering with one of the sensors
