spanneredmonkey
Electric window control module
  spanneredmonkey said:
Pt no 191 959 875
The one behind the driver sides rear trim
Unless some one near Basingstoke has one I can borrow to do some swapatronics
I'll have one if you still need one
Pt no 191 959 875
my apologies if im wrong but google search on that part number brings up 'central locking control module'
reason i ask is due to my drivers window not working - all i get is a click sound from behind the rear drivers side passenger trim & im not sure what i need to do to fix it
well would you believe it!
drivers window worked today ??? lol
think i will be checking this advice from vw rule - It might also be a good idea to check that all the wires are in correctly in the electric window control unit connector plug,
what I mean is make sure the wires are in nice and tight i.e (held in place with in these connecting blacks by two raised spike arms,
which are on each side of each female spade wire, a bit like a arrow head)
which was from http://the-corrado.net/showthread.php?t=79400
in case that helps
