leon263
Eibach camber adjustment bolts - SOLD
Here we have a set of Eibach camber adjustment bolts for any Corrado model. These bolts replace the top two bolts (one either side) where the struts bolt to the hub. When fitted, the bolts can be rotated and a built in cam arrangement will give up to 1.75 degrees of positive or negative camber.
Brand new and unused and complete with fitting instructions on the box.
List Date: 8/16/2014
For more info, click here to view the original listing: Eibach camber adjustment bolts
SOLD
the-corrado-forum
Mobile friendly version: Eibach camber adjustment bolts
Sorry to hi-jack your thread..
Do you know if these give you -1.75deg camber ontop of the factory adjustment you can do? So you can potentially end up -3deg (not that you would need it).
Thanks in advance,
liam
Good question indeed. The instructions are a bit vague on that point and merely say that the bolts will give a range of adjustment from +1.75 degrees to
-1.75 degrees. Check out the link below which explains in more detail how they work and what results you can expect.
http://www.ebay.co.uk/itm/VW-Corrado-1990-1997-Eibach-front-camber-adjuster-bolts-/230584751940?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item35afec1744
