leon263 0 Posted August 16, 2014 Eibach camber adjustment bolts Here we have a set of Eibach camber adjustment bolts for any Corrado model. These bolts replace the top two bolts (one either side) where the struts bolt to the hub. When fitted, the bolts can be rotated and a built in cam arrangement will give up to 1.75 degrees of positive or negative camber. Brand new and unused and complete with fitting instructions on the box. List Date: 8/16/2014 For more info, click here to view the original listing: Eibach camber adjustment bolts -------------------------------------- SOLD -------------------------------------- Mobile friendly version: Eibach camber adjustment bolts Go Mobile: Download the free Panjo iOS app now! Quote Share this post Link to post Share on other sites
sharpy-vr6 10 Posted August 16, 2014 Are these good for a vr6? Quote Share this post Link to post Share on other sites
leon263 0 Posted August 16, 2014 Yeah, they will suit any Corrado. Quote Share this post Link to post Share on other sites
Liam20vT 10 Posted August 18, 2014 Sorry to hi-jack your thread.. Do you know if these give you -1.75deg camber ontop of the factory adjustment you can do? So you can potentially end up -3deg (not that you would need it). Thanks in advance, liam Quote Share this post Link to post Share on other sites
leon263 0 Posted August 18, 2014 Good question indeed. The instructions are a bit vague on that point and merely say that the bolts will give a range of adjustment from +1.75 degrees to -1.75 degrees. Check out the link below which explains in more detail how they work and what results you can expect. http://www.ebay.co.uk/itm/VW-Corrado-1990-1997-Eibach-front-camber-adjuster-bolts-/230584751940?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item35afec1744 Quote Share this post Link to post Share on other sites
