GrahamU 5 Posted August 31, 2014 (edited) I removed one of the rear windows today and I would like to know what peoples opinion on re-using it is? Have I cut of the rubber on the inside or does the glass bond to the metal? Edited August 31, 2014 by rado20vT Quote Share this post Link to post Share on other sites
VW_OwneR_85 1 Posted August 31, 2014 IMO if you haven't cut/damaged the rubber finishing seal around the perimeter then it will be fine to bond back in with windscreen adhesive as that's what actually makes it weather proof , Quote Share this post Link to post Share on other sites
VEEDUBBED 0 Posted September 1, 2014 I've done it a few times, just try and get the old sealant as flat as possible and clean off the old sealant from around the aperture on the car's frame, then prime the metal using the primer contained within the kit. Be very carefull to make sure that the gap is correct between the door seal edge and edge of the window 'cos if you get it wrong or it moves the door seal will always rub against the window's rubber seal when closing the door.. Quote Share this post Link to post Share on other sites
GrahamU 5 Posted September 1, 2014 OK, thanks guys Quote Share this post Link to post Share on other sites
