fla
pcb connector needed
Not sure how to describe this. I have a pcb which has three holes for a block-type connector to be fitted either from underneath or on top and then soldered so that a connector can be pushed on the top. The spacing between the holes is about 3mm and the board itself is around 30mm x 20mm. For reference it is the ecu emulator board that you can see on ebay.
Any suggestion for a better solution would be well appreciated.
Are you sure it's 3mm not 2.54mm?
If it is 2.54 I have plenty of 3 way molex housings and crimps. Happy to stick some in the post for you tomorrow.
PM me an address.
Very kind of you, much appreciated. Let me at least cover postage?
I'll check and see if it in fact 2.54 as you advise.
