johnmac
Headlight adjusters
Alight folks,
I am after some advice, I just bought some headlight adjusters and the loom to the fuse box. The switch hasn't got the wiring. its a 1994 vr6 and i wanted to know if i will need to make some wiring from the switch to the fuse box? Also where about in the fuse box do i wire the loom up too? Any help would be great.
Cheers
I'm in the process of making a loom for headlight adjusters, but I haven't had time to work it all out yet.
Here is the info I've found by on the web;
http://the-corrado.net/showthread.php?t=31457
http://forums.kilometermagazine.com/showthread.php?795961-Installing-headlight-adjuster-motors
http://forums.vwvortex.com/showthread.php?4019629-fs-ecode-headlight-harness-corrado-100-shipped
[ATTACH=CONFIG]79743[/ATTACH]
[ATTACH=CONFIG]79744[/ATTACH]
[ATTACH=CONFIG]79745[/ATTACH]
[ATTACH=CONFIG]79746[/ATTACH]
[ATTACH=CONFIG]79747[/ATTACH]
You the man Science such a help for the one's who are not techy inclined :thumbleft:
