4pekatt
KM/H, temperature and KM-counter does not work
Hey guys!
My KM/H tacho does not work, the engine gemperature gauge does not work and the car does not count mileage anymore.
RPM and Fuel level however works like a charm.
What may cause this kind of behaviour?
Update:
So, my speedometer-thing is broken. Not the gauge in the car, but the actual sensor.
How on earth will I fix this?!
I assume the square post that replaces the end of the cable has snapped, I fixed mine by gluing it back on, lasted for a while so I could find another one
Yep, and the sensor takes the place of the cable, bolts on whare the cable would screw on, it has a square peg that goes in where the cable would normally go, it has a reed switch and magnet type setup that creates the squaure wave as it spins
