Diesel2000 10 Posted September 30, 2014 My 16v central locking works fine from the passenger side but not from the drivers side. I've stripped down the door today and checked wiring, all looks okay. When I reconnected the pump and tried the lock for the drivers door it worked once (open and closed) then stopped working. Tried disconnecting and reconnecting again and exactly the same, works once then stops. Any ideas? Quote Share this post Link to post Share on other sites
JMC 0 Posted October 9, 2014 Sorry mate, can't help, but will be keeping an eye on this thread, as I have the same issue. Quote Share this post Link to post Share on other sites
dragon green 6 Posted October 9, 2014 It's could be this [ATTACH]79919[/ATTACH] They are the same part in each door,you could swap them over,this will tell you if the part is faulty or not ! Good luck Quote Share this post Link to post Share on other sites
Diesel2000 10 Posted October 10, 2014 My issue is sorted, minor flex in the handle was stopping the rod making its limit. Easy fix. Quote Share this post Link to post Share on other sites
