awigman
reering to the left???
hi ya guys
gota problem, my c seems to rear to the left when i take my foot off the accelerator. Had the tracking done and it was fine. any ideas??
thanx
Only when you take your foot off the juice?
I would've said engine mounts, but not entirely sure they'd cause it to veer to any particular side.... :|
Does it also pull left if you're braking? Maybe it does it harder?
Wishbone bushes been looked at properly? Wheel bearings? Lower ball joints?
Take it out for a spin (not literally!) and then check how hot each wheel is afterwards - That should tell you which corner is causing problems
