Moshiko Levi 10 Posted October 26, 2014 When I put the key into the on position, my pump no longer turns on . i checked the M/02 Fuel Pumps Power - and no power when i jumped wires to the pump its start to works - The pump working when it gets direct power i installed new relay - 2 times !! - and diffrent fusebox ! but its the some i checked this : 12 Fuel Pump Relay (80, 67 or 167) 1 Main Fusebox Starter Power (not used) 2 Main Fusebox Start/Run Power connected correctly 3 To ECU (Fuel Pump Turn-On) connected correctly 4 To Fuse 18, Fuel Pump, Oxygen Sensor Heater Do not get anything 5 G2/6 (not used) 6 Main Fusebox Battery Power From 30B connected correctly 7 G2/7, T1 (not used) 8 Main Fusebox Ground (not used) 9 M/4, U1/8, G2/5 (not used) Anything else that could cause the fuel pump not to kick in? Quote Share this post Link to post Share on other sites
Moshiko Levi 10 Posted October 27, 2014 Moshiko Levi said: When I put the key into the on position, my pump no longer turns on . i checked the M/02 Fuel Pumps Power - and no power when i jumped wires to the pump its start to works - The pump working when it gets direct power i installed new relay - 2 times !! - and diffrent fusebox ! but its the some i checked this : 12 Fuel Pump Relay (80, 67 or 167) 1 Main Fusebox Starter Power (not used) 2 Main Fusebox Start/Run Power connected correctly 3 To ECU (Fuel Pump Turn-On) connected correctly 4 To Fuse 18, Fuel Pump, Oxygen Sensor Heater Do not get anything 5 G2/6 (not used) 6 Main Fusebox Battery Power From 30B connected correctly 7 G2/7, T1 (not used) 8 Main Fusebox Ground (not used) 9 M/4, U1/8, G2/5 (not used) Anything else that could cause the fuel pump not to kick in? Can I take the battery plus wire and connect it directly to M / 02? Does this solve the problem? Or it can make a problem? Or other damage? Quote Share this post Link to post Share on other sites
