rmn
retro fitting electric windows
is there much hassle in doing this?
I know i need a loom, control box, switches and regs, anything else?
It is for a mate, so we want to do this as easily and cheaply as poss, does the passat system work?
Hello
I did the same to mine and it was reasonable straight forward.
You will need all the parts you mentioned but I have no idea if the Passat parts will work?
The hardest bit is fitting the regulators but the wiring is also time consuming as it will require you to lift all the carpet out on the passanger side!
The electric window loom also includes the central locking loom and when you fit the new one you will need to remove your old central locking loom prior to fitting. The control unit sits behind the rear quarter panel on the offside.
Actually looking back on it all it took me almost a day to do!
Ermm good luck :wink:
