Alty
Fuel pump problems / Fuse box.... G60
Finally got around to booking the corrado in for a full exhaust system However, Went to drive it to the workshop and it wouldn't start so after trying a couple of things I worked out that my fuel pump wasn't kicking in.
Tested the power at the fuse box which is fine.
Traced the wiring that's all fine.
Brought a new fuel pump relay.
But still no power at the fuel pump end so I hard wired the fuel pump it whines but doesn't solve my problem....
If I need a new fuel pump (Pierburg 191 919 051 BM) Which I can seem to source what's my best bet for replacement..... ?
Now my fuse box, It's not in the best condition but it's dry and as far as I can tell everything works if I was to replace this is the fuse box a standard corrado item or model specific ?
Been looking at this one..... ?
http://www.ebay.co.uk/itm/VW-CORRADO-G60-FUSEBOX-CE2-2-0-1-8-16V-GOLF-OEM-/251706346848?pt=UK_CarsParts_Vehicles_CarParts_SM&fits=Model%3ACorrado&hash=item3a9ade0d60
appreciate any replies.
Thanks Scott
